I like the idea of using the heavy Brightside primer to level things up too.
So any opinions or real worl experiences?
I have done a fair amount of leveling up just using Rustoleum "Stops Rust". If you don't mind putting a couple extra coats of paint on and you use a sanding block, (I use the 3M hard rubber one) you can level it out quite nicely.
Gerbs
