...the guy teaching the auto body class has mentioned guide coats under primer several times now so I suppose this is his preferred way of doing it...
Guide coats under primer?? I don't really see the purpose...guide coats are usually some type of cheap spray paint sprayed on top of primer, bondo or whatever then sanded off to show high and/or low spots in the body work...that's why it's called 'guide' coat, it's used to guide the rest of the body work. If it's under the primer or bondo or whatever, you wouldn't be able to see it much less sand it off ...
