I used my grinder and twisted wire wheel
Dude, when I read that it was like fingers on a black board! You don't want to use that setup for removing paint. Sure, fine for hitting rust, but never for paint.
The best way for the DIY'er to strip paint off a car is with a variable speed sander/polisher kept at 1000 rpm with a backing pad and 80 grit paper. You can strip a car clean in 4 to 6 hours. Less noise and no risk of panel distortion.
http://www.autobodystore.com/strip_&_paint.htm
