I could always use a roller and put a thicker mixture on, say one coat, but I think it will be easier and funner to spray it.
Well that is the conclusion I came to at the end of the project. Although I was pleased with the results from the roller/Brightside, I believe that I might have had even better results if I had sprayed. But I will never know for sure until I get that opportunity...
