Pardner, here's the right rebate form:
http://www.homedepot.com/cmc_upload/HDUS...oorProducts.pdf
Whoops, I pasted that link at first and I thought I had corrected it.. Didn't bother to check. Original post is fixed now.
Put on the second spray coat, the coverage is excellent (the car is one color now!) It drives me nuts seeing my car covered in white fuzz ten minutes after I lay down the coat, and I think a bird crapped on my car this morning.
If you need to get rid of rust, I'd recommend POR-15. It's pretty expensive (a can of it was $35 at my local body supply store), but it's an all-in one product that works: it converts, seals, and primes rust.. And I've never heard of it failing.
