More water!
Believe me, I'm Wet and Wild! Lots of water and a bit of dish soap. Thanks, though for the pointers. My hood is a very flat panel (Scirocco MK 2), and with a wet fine grit paper I often get a vacuum situation that disrupts my sanding motion. I mean it really sucks it down, and then A) the paper flies right out of my fingers if I'm using a foam block, or B) the harder rubber block comes to a dead stop. I'm using short strokes, 3-5 inches, one direction. Maybe I'm pressing down too hard, but it seems if I dont put any pressure, then I don't get any sanding done...
You got it. You are using too much pressure. The sanding takes time, lots of time. You are squeezing the water out from under the paper and causing in effect that same thing as not using enough water.
Good luck,
Jason
