"the rustoleum i have not used, but it's very simmilar to the tremclad which i think is the same as rustoleum professional."
I have been testing with the Rustoleum Stops Rust. Has anybody tested with both the Stops Rust and the Professional? If the Tremclad may be more similar to the Professional, maybe I should do some testing with the Professional.....
Any Comments??
Thanks, Mark
I would get the professional if you have a choice. Some colors aren't available (or readily available) in the professional type. I've gotten a good shine out of the red professional stuff, and im painting my car white with the stops rust stuff. I hope I can get the white to shine like the red did.
I will get a hold of some Professional and test it out this weekend. I will report what I find. Thanks, Mark E.
