Speaking of primer the bed of the truck showed 30+ years of use and since this isn't a show truck I used Rustoleum rusty metal primer straight out of the can and rollered it on, came out so smooth it looked like it had been sprayed.
I did sand and used a heavy rotary wire brush to remove any loose rust or scale first.
