Quick prep question:
I've rolled on the first couple coats, and now see some areas that might require bondo touch up.
Most of them are small - like the size of a quarter or less. Can I just rough up the area with maybe 400 grit and bondo over the paint or do I need to sand back down to primer or to bare metal?
Or just re-prime it and bondo over the primer?
Thanks!
