Marq thanks for the advice!
I'll take some 800 grit to it tonight. I have complete coverage in all areas by about one coat.. As long as I go lightly when I sand I think I'll be okay and won't cut through the paint. The paint is really thin even with 4 coats at this point.
Would you wet sand (or dry sand) 800 grit? I've been wet sanding lightly every 2 coats so it's due for a sanding really. My first wet sand was 600 grit.
I still have to go and find the post you made for me sometime last fall about how to polish. I have to go and purchase the pads for my porter cable.
Perhaps I can convince friends to come help sand tonight for a few beers... *grin*
