Hi all.
I am new to moparts, but have been following some of the other forums on the roller paint job.
I am about half way thru painting my 1970 Mustang Fastback. I am painting it jet gloss black using the Brightside teflon paint. I am getting good results except for some light-coloured blotchy marks you can see if you look up close and against the light. Has anyone elese painted their car gloss black using the Brightside paint ? I suspect these marks wont show on lighter colours.
Here is a pic if the completed front guard. It was polished using a Festo rotary polisher.
http://users.tpg.com.au/fanile//my-car-paint1.bmp
I am now trying Brightside's own undercoat called 'PreKote' to see if that gets rid of the blotches.
The guard in the pic has 8 coats and cured for 30 days prior to final wet-sanding with 2000 grit paper and then polishing.
Cheers,
Frank.
