Has anyone used marine topside paint such as interlux or epifanes over rustoleum primer? I will be going from metallic blue gray to cream, and will need a lot of primer. Using rustoleum for the primer layer would save a lot of money vs epifanes or interlux primer.
Thanks!
Been previously discussed in depth. Short answer is YES you can paint Brightside on top of Tremclad/Rustoleum...
