If you have a spray gun just go down to your local autoparts store and get a quart of Dupilcolor gray lacquer primer along with some lacquer thinner and shoot the car, then a light sand tack rag and start rolling.
Look at the door then the rest I fully primed the door & the coverage was much better.
