[img]http://i25.photobucket.com/albums/c99/BAD91Si/fogsonly.jpg?t=1187934955[/img]
test
Still no image. I don't know if you are editing those or not, but my link from photobucket shows as IMG in all uppercase when I post it into a message, and mine work.
Glad Marq got to you on the other questions ... since power went out here as I was gonna reply.
From what I recall about the lengthy discussion on the Wagner here it was determined that the CHEAPO Wagners do not work for an auto ... if I remember correctly, it was determined that if Wagner was too embarassed to put the PSI of the gun on the box, don't use it. As for all the other particulars, there was some discussion a while back, and most of it started from work found by members of honda-tech or one of the other honda forums. As for all the drawbacks from that method, I think Marq hit on all of them.
