the way I did it was to put it on thin and even, then roll over the top different directions with just the weight of the roller doing the work to make it perfectly uniform thickness. It smoothed it so good I never had to worry about it leveling. It also made the orange peel much finer.
Did you also squeeze out most of the paint by rolling the brush hard on the ridges? how many rolls would you do if so?
