Yeah, tell me about it. I had the same problem. That's why i was thinking it might be better to get all 8 or 10 of your layers down before you start wet sanding.
I spent countless hours sanding off the paint I had just applied, only to end up with about as much paint as I had before I started sanding. Or even less, in the spots where I sanded all the way through to the primer.
