hey Marq, I've been contemplating the brightside paint. They do have the EXACT color I want and apperantly it shines better. I looked on the brightside site and its only about $10 more than rustoleum so maybe if I beg my parents the'll buy me some. But my question is this, can I use the rustoleum primer with brightside?
Yes.. you can use the Brightside paint over the Rustoleum primer OR the Rustoleum paint.
You can save a few bucks by doing your initial painting with the Rustoleum primer... and then painting with the Rustoleum paint. Once you have color coverage using the Rustoleum paint, you can then switch to the Brightside paint to do the final coats.
Basically that is how my car ended up being done... because I switched paints half-way through the paint job...and still no problems.....
