You should have no problem using lacquer primer under this paint. Just make sure that you don't apply lacquer based products over an enamel (If you do, it will only take a few seconds to see why.) I have used a lacquer primer as well as rusto primer with no ill effects from either.
Good luck
-Trent
so lacquer primer is ok to use under the RustOleum. I just want to be double sure, cuz im getting tired of sanding stuff.
and whats the difference in the RustOleum paints??
this is what im going to be painting.. .
