That sounds like POR-15 or Rustbullet.
Great for sealing your floorpans or trunk pan. I can't imagine using it on the body.
harminoff, read again what the product says it will do. It will not act as a filler to create a smooth surface, it only treats the metal. It is more like a paint. You will still need to use filler over any irregular surface to get it straight.
