How long should I realistically wait before wet sanding and polishing?
The reason I ask is I can't replace the drip molding until the polishing is done and therefore I can't replace the rear quarter windows. Or if I do, I can't seal them into place as they need to be.
I can use the car for a short while with them just screwed into place, but I don't want to press my luck.
It kinda depends. Can you still dent the paint with your fingernail? If so it is much too soft. With catalyzed 2k I can usually wetsand/buff the next day. With uncatalyzed urethane... maybe a week? Hard to say.
