Ace paint "stop rust" tintable Color Matching?
Do you think they"Ace" can get it to match B5
blue or get real close to it? & What do you Thin it with ?
& Can you use a HVLP gun"air"? & can you clear coat it? if so what kind of clear coat?
This is for a `70 `Cuda B5 int.&ext.Want to do it cheap.But Don`t want it to LOOK CHEAP!
Thanks, JZ`Cuda
NEED MORE INFO on the HVLP air gun & Clear coat & can you use Thiner?
Thanks again!,JZ`Cuda
