Hey Marq, Aussie Driver or Exit,
or others using Brightside....I am using Aussie Drivers ratio of Brightside, penetrol and mineral spirits. the first two coats went down fantastic, almost like glass. I did my first wet sand with 600 and then third coat...that is where things changed a little. I stated to get very small bubbles that would magicaly appear after I thought things were perfect...they came in small patches....so I did my second wetsand with 600 thinking that would clear things up.
on my fourth coat I have some major orange peel and the same small patches of micro-bubbles...this all occured ONLY where I had wetsanded the previous "mistakes".
so I have two questions:
do you think those areas were contaminated somehow?
will the final 1000/1500 wetsand and the polish remove this? or do I need to sand again with 600 and lay another coat down and then do the finalsand/polish/wax?
