How long should I realistically wait before wet sanding and polishing?
The reason I ask is I can't replace the drip molding until the polishing is done and therefore I can't replace the rear quarter windows. Or if I do, I can't seal them into place as they need to be.
I can use the car for a short while with them just screwed into place, but I don't want to press my luck.
