Put down the first coat on the roof and hood.
Painted
http://farm2.static.flickr.com/1117/890683462_186bc2be47_o.jpg
The roller marks in this picture could be worked out by running different directions, and not so much pressure. You can put a bit more paint on it and work it longer until just before it gets tacky.
I work the paint more than most pictures I've seen...
When I put a coat on the vette, I must have went over the whole thing 5-7 times each coat, working it different directions until it stopped running and showing lines. You have to work it lightly.
- Just my 2 cents here.
I totaly agree. i never had lines or marks like that....my coats were transparent but always very even. I went over it and over it spreading it around and evening it out. remember this is the cheap solution not the mirical paint job in a minute job.
BTW i have about 8 coats on my sidecar now but only pics up to the 6th or so. I can still see through it in spots so a few more coats in the works when i get free time again!! here is my pictures of progress.
http://rides.webshots.com/album/559630508GUGsFC
