I found that wiping the tape with a cloth dampened in mineral spirits as you removed it helped as well. Once you get the tape lifted at one end, wipe the adhesive side in the direction you are removing the tape.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
