so far, this central hub and cross spoke which makes up for the bulk of the 1-1/2 Lbs or 24 ounces in weight on the stock horn ring is now 6 ounces in Aluminum as you see it here.
Once I get the outer ring itself (not pictured) rolled welded and trimmed to shape, it should be a fraction of its pot metal cousins weight.
