Well, I took a hooky break to install my titanium front wheel lug studs on the aluminum brake drum hub. Saved almost 12 ounces or 3/4 Lb between the both sides. A few other things that I have done at the beginning of the Winter has now put the car solidly in the upper 3000 LB mark. For now, I'll exorcise it from its cave and have some limited fun in the sun during the season. It will be within striking distance of 2900 lbs by next Spring. That will be my cap.
