Quote: The old Mopar chrome one might create more heat in the fluid than its worth. I'd rather stay with an old and true deep regular steel one if the budget is tight. The steel one is I believe lighter than the cast aluminum types.
The 518 pans are deeper and bolt right up. That's what I use on my 727's.
