Quote: I just wanted to post cutting down centerlink to clear pan like I had to do on my car...
i'm sure you can get pretty crazy with it...
I like to see and hear more about this. mine rubs on the pan !
from the castle nuts down that slide area look at the bar... wacked off in milling machine then I spent time on a belt sander rounding and smoothing out some. pretty much everywhere the pan had rubbed paint off the bar and by the depth of "pan rub areas" I that area.
