The mold is stiff as heck. Wind should be no problem. I use to stamp steal. Aluminum should be doable once or twice in a mold like this. I would build it a little different if I knew I was going to try and stamp a part in it. I built a wood die, do my Trans tunnel. Used the tractor bucket as a press lmao 😁
