i forgot about your rear wheel "hubcaps" ! i thought i remembered the front wheels being "fake-o" steel, however. when you get to re-doing the wiring, any idea if you will be removing any unnecessary circuits, or just tiding up ? 2-3 pounds there, or does it just look worse that it really is ? what about an aluminum column tube, or did you already do that ?
beer
