Al, did you weigh the cylinder heads to see what the weight difference is between the iron and aluminum? Switching to aluminum heads and rocker stands should be at least 50lbs, no?
Stroker pistons will be shorter and weigh less...
Wilwood discs, k frame mods, aluminum radiator, get rid of some of the chrome cup gauges on the cowl - switch out the braided steel lines for some stealth black braided stuff... easy peasy.
