Quote: I don't know about that, it's really just an old worn out bracket car with a fancy VIN
I've only noticed one place where the body is tweaked - there's a crack in the roof at corner of the passenger side rear window. It's not a post car so that's no surprise. I guess it was plenty stiff enough even with all the metal cut out of it - with the bar in. The car was modified in about 76 and was raced regularly from then until I ended up with it.
