Shaft weight is not so much a gain as it is dead weight removal. The weight, even as rotating is too small in diameter to make much difference. Lighter tires sitting at the outer parameters of the wheels will probably make more of a difference ET wise than a lighter shaft. Of course I went ahead and pulled the trigger on the very last metal matrix aluminum shaft from Dynotech quite a few years back.
