The finished result. The dash frame itself, lost 3 lbs, with just some trimming, and removing any unused clip, tab, waste that can't be seen. The ash tray is gutted, and just bolted into place, and the glove box door, had the hinge removed, and is held into place with magnets. All my MSD/wiring is tucked up under the dash, and being able to removed the glove box door easily, will come in handy.
