While we're on the doors, here is a stock striker with backing plate and mounting hardware, Underneath is the new aluminum backing plate I cut out. When I get the 7075 Aluminum strikers from Detroit where they're being milled, I'll post up a flick or two. This process only saves about 1-1/2 Lbs between the both sides.
