When I broke a perch,I had the rear centered and installed sliders.My street tires do rub-the-tub on the inside on sharp turns or uneven surfaces. Will be gutting the steering column soon and expect to lose some weight there.Also want to add a removable steering wheel,it's getting hard for the old guy to climb over that door bar Was 3700lbs,now 3500 lbs and falling
HEMI-ITIS has no cure. My condition is fully BLOWN!!
