A New York minute that we all have not spoken legend. I figured that some of you that are still insane in the membrane like myself would like to have a peek into the Aluminum alloy front Drum hubs that Dr. Diff made. They are awesome and fit like a glove of course. The only glitch being the only offshore made item in the whole kit, the grease cap. This grease cap was stubborn to find its new home and I didn't want to pound on it even with the soft rubber mallet. I'll figure it out on how to seat it properly on the Hub later, but here's the stock one with the long 3" studs installed years back. It weighs in at 5-1/2 Lbs as you see it here with only the rear bearing and races still in it.
