I use the round button head bolts for my glass bumpers. Took advantage of the heat wave and spent time in area 59.Removed the clutch/brake assembly todayTurns out the clutch pedal assembly simply bolts onto the brake assembly.Now I need a shorter bolt and an aluminum brake pedal!! Me thinks I can drop 10 lbs with the master and clutch pedal assembly
HEMI-ITIS has no cure. My condition is fully BLOWN!!
