I figured out how to bend the bridge flaps on both ends using my rubber mallet and hammer as you see it here to make the gradual elliptical bends. Once that is done, they get welded to the main side walls to add super strength. After that, the boxed cavity where the trans mount resides will be introduced. More later.
