He means the cat walk section running along the whole brim. Just has to be welded well and shut. Grounded smooth after that, it becomes more beautiful and wind slick. Probably a few pounds right there. The spot welds that held that portion together was shoddy at best from the factory. I would jig and or clamp the cars front longitude together while you cut to keep things straight and level.
