Are you referring to internals such as rods, crank, valves, rockers etc. As far as the block, I never cut off the mounting ears and or machined the excess stuff off, also I'm staying iron all the way especially with the talk of shift and clearance jumps associated with aluminum. Do you have any pointers? Admire your approach to built ups over the years.
