You're right. At a lean mean 180 Lbs wet, I could use a few pounds. Though at race time having only the ignition key (aluminum types optional) and no underclothing and socks after fasting the night before make for a n extra light weight set-up. LOL. At least the 10 spot was applied to the rear of the car where it doesn't concern me as much. Now if I can find an inch or two rearward to mount my seat........ There are some gems coming down the pipeline soon when I get a chance in between hectic work. Ya'll will read with amazement.
