This is a follow up from my post about the inside door handle pivot weight comparisons. If you go back to that post you will see that the two pivots on the scale are different! I didn't notice this until I was making the lighter ones even lighter! I have attached a picture showing the pivots from two different suppliers. Notice how the one on the right is cut out compared to the one on the left. Again same part two different suppliers one lighter than the other. MJ
