If i was using rubber bushings I would have went with a cupped washer but the poly bushings I dont think it matters one bit.
After I cut a section of the spindle off, I used a die grinder and took off the casting ridge all the way around so yes its narrower but I think in a good way. I still think more could come off
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
