Here's the outer strengthening wing.
As you can see, the stresses associated with a hammering in a compound bend made some corners collapse or crack. This is reduced almost entirely by drilling small holes at the end of the bend and or crack thus allowing the metal to give a little and then filling in the holes later with weld.
