I can tell you this much about aluminum hard line. It is plain HARD to both bend and maneuver into place if you are going the route that I did which is to mimic the factory line route. My hands and fingers were hurting for days. I used all the proper tools to bend and flare, but still a pain. The end results is both clean and factory looking except that the line is 1/2 inch.
