Speaking of losing weight on the crank, you did read about Ford using a flat crank in the 2015 Mustang variant V8's. That has to take more weight off than just using a cast crank. Evidently they worked out the harmonics problem.... and I didn't read anything about separate balance shafts either. I'm waiting to see that become the big thing in performance engines.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
