Quote: If I'm following you right, you have tried to make a carbon hood from your original fiberglass one as a template? I just saw a purple hood like yours with the same 6 barrel scoop on this board for sale. I thought it was your old one up for sale. in any case, good luck with what ever you end with. On some occasions, I've failed at things and had to start all over. My hood gave me grey hairs when I first started on that.
I`m confusing sometimes, sorry................I had a 12 lb. glass hood made and tried the ol skool pro stock scoop and after a day and a half I`m done trying to make that work. So, I may just use the old 6 pack scoop or buy a new one since it is partly up in my tape line from the roof to the hood and my afr`s were dead solid at 12.8 @ wot IF that even matters.............My temperment sucks sometimes and get real frustrated when I can`t master something faster..............
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
