Ray how much weight do you think you saved with the rack conversion? How much does that rack weigh vs the steering box? Thanks
At one time I had the weights written down. I think just my k frame weighed 36lbs and ended up being 19 when done. A gear box, arms and steering linkage are all much heavier than a rack. Probably an easy 10lbs there. And then this year I got another 12 lbs out of the suspension lightning the spindle, lower control arms and switching to coilovers
I will weight my stock stuff but I'm guessing more than 10 lbs. for the steering
